The passenger wiper sits higher than the one on the driver's side, and I think it creates drag. Or not? See the picture below. So I tried to remove it today, but I failed due to corrosion, there is no movement at all after the bolt is removed. Is there a trick to get this out without any special material (and without demolishing the mechanism) ? I put some WD40 on it and will try it again tomorrow ...
