Old 05-04-2020, 11:45 AM   #21 (permalink)
GreenTDI's Avatar
GreenTDI - '11 Skoda Fabia Estate R3 1.2 CRTDI
Diesel
90 day: 65.02 mpg (US)
The passenger wiper sits higher than the one on the driver's side, and I think it creates drag. Or not? See the picture below. So I tried to remove it today, but I failed due to corrosion, there is no movement at all after the bolt is removed. Is there a trick to get this out without any special material (and without demolishing the mechanism) ? I put some WD40 on it and will try it again tomorrow ...
See my thread: https://ecomodder.com/forum/showthre...mpg-38318.html
Old 05-04-2020, 04:53 PM   #22 (permalink)
マット
M_a_t_t's Avatar
The Van - '95 Chevy Astro Cl V8 Swapped
Team Chevy
90 day: 7.84 mpg (US)
The new bike - '17 Kawasaki Versys X 300 abs
Motorcycle
90 day: 71.94 mpg (US)
The Mercury - '95 Mercury Tracer Trio
Team Ford
90 day: 34.35 mpg (US)
Toyota - '22 Toyota Corolla Hatchback
90 day: 40.11 mpg (US)
Are you trying to remove the wiper or the whole arm?
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
Old 05-04-2020, 04:55 PM   #23 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Some guys take that one off. I did. It is impossible for people with our tools and techniques to know what effect it really has, but it is plausible that it disturbs airflow before it moves downstream. I took mine off and adjusted the driver one to sit slightly lower in the well while at rest.
GreenTDI (05-05-2020)
Old 05-05-2020, 10:33 AM   #24 (permalink)
GreenTDI's Avatar
Diesel
I did it! With some help from YouTube. I took the passenger wiper arm completely off. Meanwhile, I also lowered the wiper on the driver's side so that it's more in the 'bubble' and catches less wind. Thanks California98Civic for that idea!
I will also swap the current 20" wiper by a 26" one, to make up the loss of the other one (a little). It should fit.
Wipers where in need of replacement, it will now cost me less and thus compensates for the purchase of the grill cover
Technique of removing a corroded wiper arm (see photo's below or the movie on YouTube that helped me
- Screw another bolt onto the post, 1/2 to maximum 3/4 (to protect the thread)
- Place a wrench or pincers under the arm to apply upward force while hitting the bolt with a hammer.
Rusted grit is released and after another few hard strokes the arm comes loose.
ID:	28030   Click image for larger version
ID:	28031   Click image for larger version
The Following User Says Thank You to GreenTDI For This Useful Post:
California98Civic (05-05-2020)
Old 05-05-2020, 12:34 PM   #25 (permalink)
Cyborg ECU
Good deal! Surprised that guy didn't hit the siexzed stud with a little penetrant oil first. It probably would reduce the hammering, which seems hard enough to risk windshield damage. Very clever though, especially reattaching the nut first. Nice hack.
Old 05-09-2020, 11:51 AM   #26 (permalink)
GreenTDI's Avatar
Diesel
Tomorrow I'm going to try to get my first 70 MPG trip of the year. I have done it twice since I got the car 9 years ago, the best one was 77 MPG and the second best was 71,6 MPG without modifications. But those attempts were in ideal summer circumstances, distances from 200 to 350 miles and always measured in one direction, slightly declining.
Tomorrow I have to go back, forth and a little detour for 80 miles, where I usually get ~61 MPG (63,6 MPG with only a closed grill). So it will be a challenge, considering that I will maintain speed limits and not less than 60 MPH on highways.
Mods so far:
- grill block
- tires at 40 psi
- wiper delete
- side mirror folded in
- Removed an incredible 112 pounds of exces weight (2 child seats, spare wheel, tools and all kind of stuff)
- I also closed the alloy rims with strong tape to see if it has really effect. If it turns out to be effective, the next step could be proper closed hubcap/rims.
Old 05-09-2020, 09:31 PM   #27 (permalink)
Cyborg ECU
Mods so far:
- grill block
- tires at 40 psi
- wiper delete
That is a good set of mods. I suspect it won't be too hard to hit 70 mpg. Keep us posted.
Old 05-10-2020, 09:22 AM   #28 (permalink)
GreenTDI's Avatar
Diesel
Yes, me and my Green TDI succeeded!
Result: 71,3 MPG
Distance: 82 miles
Average speed: 48 MPH
Direction: back and forth
Weather: light rain, 19°C, 10 MPH wind from different directions
80% highway at 62 MPH, 20% city driving
Couldn't believe it at first because it was raining and I had bad luck at most intersections. I even had to brake on the highway for a bunch of pheasants crossing
I did check the actual consumption at 62 MPH on the same stretch as the last time, and fluctuated between 78,4 and 81,1 MPG! It seems to be a massive improvement: 69,2 - 71,3 MPG stock.
ID:	28112   Click image for larger version
Old 05-10-2020, 08:58 PM   #29 (permalink)
Cyborg ECU
Result: 71,3 MPG
Distance: 82 miles
Congrats! I will record it under SRA class in the 70 MPG challenge OP. Woot woot!
GreenTDI (05-11-2020)
Old 05-11-2020, 01:52 AM   #30 (permalink)
Wow!!! Congrats it is awesome I am a bit jealous as I cannot for the moment go much under 4l/100km and my instantenuous fuel consumption at 62mph (real speed, so about 105 at the gauge) is more about 4l/100km. But it is true I haven't used all your tricks now and I live in the mountain. Even with much care, it can't be helped that a lot of gasoline be wasted downhill in brake dust and heat. Do you know the official SCd figure for your car? Mine is 0.60m2, and at 80km/h my engine revs at 1300rpm, which is fine but couldn't be lower.
I might try overinflating the tyres but I will only do that on long trips.
The Following User Says Thank You to ptitviet For This Useful Post:
