Old 05-07-2020, 01:03 PM   #3 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
I hate water damage. Cut it out and do it right or pay dearly later.
Exactly. This started with a small section of rot on some trim I found before I started repainting the house. I took the trim off, then the sheeting, then had to cut out and replace some of the framing on the roof and chimney. The builders didn't install the flashing correctly between the chimney and roof on the upslope side of the chimney and water had been running down wall between the siding and sheeting for years.
The Following User Says Thank You to JSH For This Useful Post:
Xist (04-01-2021)
