Old 05-09-2020, 10:14 PM   #78 (permalink)
JulianEdgar
Originally Posted by j-c-c View Post
The "expert" is correcting the terminology here I see. In that the device in use is effectively a "wing" designed to induce differential pressure, being used vertically when differential pressure has little use, which only adds to drag, size, weight, complexity, etc. An infinitely thin correctly configured "vane" would reduce all these issues, as I see it, what say the "expert"?
I see he included the description "constant" (regarding crossection?), that would be my starting place.
The beauty of this world is that we can all try out different approaches and then share the results. If holding a constant cross-section and not using an aerofoil are your preferred approach, why not do both those things and tell us how you go?
