Old 05-12-2020, 12:48 PM   #49 (permalink)
alexbrown64
So i have installed Glens touch screen MPGuino. Its a great unit. I built a box to house the whole unit in (screen, computer, ribbon). Once wired up and mounted, it was time for a test.
Fired up great. Unit is set up for switched power. Memory function all good.
RPM dead on straight out of the gate.
Hot idle was 3lt per hour. I will adjust to 1.8lt.
Only problem is the commonly noted Speedo jumping around. I have tried the VSS delay with no result. Will look at wiring tomorrow, but i think the signal needs cleaning up. I run a yellow box signal converter that i may need to bi-pass for this unit. Glen has offered to run an oscilloscope over the signal.
Anyway, looking good so far, and amazing unit for and OBD1 Jeep.
Cheers,
