Old 05-13-2020, 03:48 PM   #11 (permalink)
oil pan 4
Originally Posted by California98Civic View Post
Wouldn't antiseize risk a torqued bolt or nut backing out over time? That is the reason I don't use it unless specifically recommended. Not true, I guess, huh? You can apply it everywhere?
I use that stuff on just about everything once I realized there appears to be no difference in the bolts backing off.
When my friend got his Toyota pickup it was 10 years old. It needed some suspension work. Stuff had to be taken apart with a torch or sawsall. 12 years later he is having to redo some of that suspension work again as its wearing out again. Everything that was antiseized just came apart.
The Following 2 Users Say Thank You to oil pan 4 For This Useful Post:
California98Civic (05-13-2020), Daox (05-14-2020)
