Old 05-16-2020, 01:51 PM   #40 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by GreenTDI View Post
It's a pity that the weight of a tire is never mentioned as a specification.
The almost worn out tires that the car is now driving on, has already lost a lot of thread and therefore weight. Also tires have the least rolling resistance at the end of their life (but also less grip which I sometimes notice).
Anyway, the new tires must have a bigger diameter to change the gearing a bit. That's another aspect of tires.
Current 195/55 let the car go 62 (real) mph at 2000 rpm.
Taller 175/70 for example, would increase it with 5% (~65 mph) at same engine speed.
So yes, a lot to think about!
Right. Bigger diameter, taller gearing, but also the weight is further from the hub so a hit from rotating mass. You can get tire weights at tirerack.com
