Originally Posted by rmay635703
Older cars (pre 2000) had 2 way CATS or modified 3 way
which aren’t affected by that issue, they also more importantly didn’t need to meet the more stringent NOx limits of later years so some NOx could pass a full trap without issue.
The Insight and newer had a Nox trap and would cycle lean to rich to make sure the cat stayed lit and the NOx levels didn’t increase after the NOx trap filled.
So, perhaps as the mixture goes lean, the CAT cools, and its efficiency decreases. That would mean a DIY lean burn system would inevitably cough out more NOx, which was a major culprit in SoCal smog back in the bad old days of fog banks in the desert.
