Originally Posted by aerohead
I'd just follow Ford's contour,as if you were completing it with a french curve. I'd also just drop the side aprons (capping plates) down the the bottom of the glass, enclosing as much side area as you can. You'll have a little more blind-spot, so use your side mirrors frequently to know your driving environment at all times.
can you elaborate on that with a crude drawing on top of my photo?
also, took a picture after few days on a dusty road, notice that the sections in the sides have less dust than the center section which does not have a hole....so this means....what ? that the holes are working or not?
