Thread: Measuring stuff
Old 05-20-2020, 12:07 PM   #15 (permalink)
redneck
Nice...
I wool tufted the diffuser section of the undertray and took some pics. They're hard to take because you basically need to lie on the ground and snap the shutter as the car drives past.
Maybe mount a small camera like a cheap backup or dash cam video camera to see or record what’s happening instead of trying to take pictures as the vehicle passes. If your think the camera or mounts might affect the air flow patterns then something else may be needed. In the movie industry when rolling action shots are needed, the cameras are often mounted to a “Jib” on another vehicle. A jib being a long supported pole. Several pieces of 1/2” EMT (electrical metal tubing) welded or bolted together in a triangular shape and mounted solidly to the front of a second vehicle with the camera mounted low should work nicely and would be easy to fabricate.
Again, just spitballing...
Donald J Trump 8/21/21
Disclaimer...
But...
I play one on the internet.
bobo333 (05-20-2020)
