Old 05-21-2020, 04:12 PM   #104 (permalink)
jjackstone
OK.That kind of makes sense for a 10 series 7 parallel pack with 2000 mah/cell.The mah would stay the same for the series section at 2000 mah/10 cells. Then by paralleling they would multiply by 2000 by 7 to give you 14000 mah or 14 Ah. Also the voltages you stated would be 36 volts nominal with ten cells in series and fully charge to approximately 42 volts. However, if you paid for Lifepo4 cells you kind of got ripped off because Lifepo4 has two to three time the life expectancy of standard lithium ion. Lifepo4 should be have 1500-2000 full recharge cycles where lithium ion only has 500-1000.
JJ
The Following User Says Thank You to jjackstone For This Useful Post:
California98Civic (05-21-2020)
