Originally Posted by JulianEdgar
So I tried some rear Edgarwits to see if I could reduce wake size. These were additional to the front ones, and taller. GOE222 true aerofoil profile.
I did some throttle stop testing with the following results (km/h at 30 per cent throttle, low-moderate gusty headwind):
- No rear Edgarwits: 95
- 1 finger rear gap: 93
- 2 finger rear gap: 95
- 3 finder rear gap (ie about parallel): 96
- 4 finger rear gap (ie diverging): 96.5
That would make 4 finger vs std about 3 per cent improved in drag.
4 finger gap:
For people interested, but having other cars, don't forget Insight boat-tails a lot with its narrower rear track.
Interesting to see the better performance at the rear with the diverging duct - opposite to what occurred at the front.
I'll do some more testing on a still day, but to me this result is borderline. I'd need to see a big jump in drag reduction on a still day to go in this direction.
Would the rear wing experiment not be just a vertical "blowen diffuser "?
What was the wind direction for the Eroding Clay test? It will help with interpretation of the results.
My interpretation based on what I see, assuming wind from the left ( American driver side)
▪ The airfoil profile has too much curve on the convex side , evidenced by severe separation less than 1/3 Cord at the bottom and 1/4 cord at the top. This would be a good application for test of VG's in a specific use case, (maintenance of attached flow in extreme angle of attack as demonstrated). I have seen a proper demonstration you're witty Edgar's work as intended to a benefit, is there room for improvement, possibly/ possible not.
¿ I'm taking it this was the downwind side?
▪ The up wind /drivers side I expect to see almost,but not quite,a poler opposite. Eg cleaned off by attached flow out side and dirty/covered by sepperated flow on the convex wing surface.
▪ the up wind turning vane / wing is acting like a blown diffuser blowing the wrong direction ,at a yaw angle between 45-180° at typical road going speeds.
E.G. By ~45° yaw (angle of attack~ 90° negative) the wing is past full stall and by ~50°ish yaw it becomes a blowen diffuser.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg :
31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
