Old 05-26-2020, 10:34 AM   #534 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
Originally Posted by samwichse View Post
Did your trailer have brakes? Because I can imagine that heavy trailer pushing your light back end right around and jackknifing under even moderate emergency braking...
Trailer brakes make such a huge difference in the weight disparity you can tow with anything. I used to tow a 12k lb trailer (tractor + implements + spray tanks loaded with lots of mix) with a late 70's Dodge Ram 2500. Checked those brakes every. single. time. I was leaving because turning them off, you could feel the back end wanting to come around giving the brakes a solid tap at 10mph, and I was towing through central PA.
No trailer brakes, and I don't plan to load it up that much again.
I wasn't aware it was as heavy until I got home, but it was an interesting proof of concept. I've seen others who've broken their rear bumper bar off carrying a bicycle rack on their Insight, and I'm glad to see my design is so much more robust.
MetroMPG (05-27-2020)
