Old 05-28-2020, 10:05 AM   #42 (permalink)
bobo333
F Truck - '77 Ford F100 2x4, single cab, lwb
90 day: 8.75 mpg (US)
Bombodore - '98 Holden Commodore Exec Wagon
90 day: 21.35 mpg (US)
Civic - '93 Honda Civic GL
90 day: 36.62 mpg (US)
Jim The Prius - '09 Toyota Prius
90 day: 36.66 mpg (US)
Originally Posted by Yippeekyaa View Post
Just a suggestion from my own experiences towing with a Prius. 100k miles plus so far on two different prius all over the continental USA. Air bags in the rear leaf springs! They helped lift the rear up to level things out due to the small camper and the added weight of camping gear. They also have the option of a small on board air compressor which could come in handy for many uses. Worked great on the air mattress.
Edit: this was the system i installed.
https://www.sdtrucksprings.com/index...AaAun3EALw_wcB
Prii don't have leaf springs, I'm assuming you're talking about the coil springs on the gen3 and above?
I have a full computer controlled air suspension system on my other car and it's 100% the best modification I've ever done, the comfort, adjustability and load capacity are second to none and the handling is great too!
Unfortunately the system cost twice as much as the whole car so I can't really justify doing it again any time soon, I have been tossing up slowly fitting a much less automated system to the Prius, starting with the rear struts and a basic compressor, then upgrading to a tank, valves and front struts later on but I havnt been able to find the specs on the height range and load capacity of Gen2 Prius struts. They're mostly used for lowering the car right to the ground for style points.
(Posted in 2020) 2009 Prius Off Road project: https://ecomodder.com/forum/showthre...ide-38366.html
(Posted in 2012) 1977 F100 Project: http://ecomodder.com/forum/showthrea...tml#post310326
