Old 05-28-2020, 08:35 AM   #41 (permalink)
Goldie - '11 Toyota Prius
90 day: 48.93 mpg (US)
Just a suggestion from my own experiences towing with a Prius. 100k miles plus so far on two different prius all over the continental USA. Air bags in the rear leaf springs! They helped lift the rear up to level things out due to the small camper and the added weight of camping gear. They also have the option of a small on board air compressor which could come in handy for many uses. Worked great on the air mattress.
Edit: this was the system i installed.
https://www.sdtrucksprings.com/index...AaAun3EALw_wcB
https://ecomodder.com/forum/em-fuel-log.php?vehicleid=10690][ img] https://ecomodder.com/forum/fe-graphs/sig10690a.png[/img][/url]
The Following User Says Thank You to Yippeekyaa For This Useful Post:
MetroMPG (06-11-2020)
Old 05-28-2020, 09:05 AM   #42 (permalink)
F Truck - '77 Ford F100 2x4, single cab, lwb
90 day: 8.75 mpg (US)
Bombodore - '98 Holden Commodore Exec Wagon
90 day: 21.35 mpg (US)
Civic - '93 Honda Civic GL
90 day: 36.62 mpg (US)
Jim The Prius - '09 Toyota Prius
90 day: 36.66 mpg (US)
Prii don't have leaf springs, I'm assuming you're talking about the coil springs on the gen3 and above?
I have a full computer controlled air suspension system on my other car and it's 100% the best modification I've ever done, the comfort, adjustability and load capacity are second to none and the handling is great too!
Unfortunately the system cost twice as much as the whole car so I can't really justify doing it again any time soon, I have been tossing up slowly fitting a much less automated system to the Prius, starting with the rear struts and a basic compressor, then upgrading to a tank, valves and front struts later on but I havnt been able to find the specs on the height range and load capacity of Gen2 Prius struts. They're mostly used for lowering the car right to the ground for style points.
(Posted in 2020) 2009 Prius Off Road project: https://ecomodder.com/forum/showthre...ide-38366.html
(Posted in 2012) 1977 F100 Project: http://ecomodder.com/forum/showthrea...tml#post310326
Old 05-28-2020, 09:51 AM   #43 (permalink)
Yes, the air bags fit inside the coil springs. From deflated to inflated i gain almost 3 inches of lift at 60 psi. The entire system cost me less than 150$ us. Biggest advantage was no longer getting flashed at because oncoming traffic thought i had high beams on due to the rear sag. Plus it just drove better.
The Following 2 Users Say Thank You to Yippeekyaa For This Useful Post:
bobo333 (05-28-2020), MetroMPG (06-11-2020)
Old 05-28-2020, 10:07 AM   #44 (permalink)
Unfortunately I cant do that with the gen2 prius as the rear shock absorbers are inside the coil springs rather than next to it like gen3+. Instead i need to replace the whole struck with an airstrut which is much more than $150 and has no coil spring to hold the car up when the bags are deflated.
Old 05-30-2020, 05:10 PM   #45 (permalink)
Jetta - '01 Volkswagen Jetta TDI
Nice Transformation.
Bummer on not being able to fit bags. You got the grinder out so you are halfway to fitting those tires. Some strut spacers may be the other half (How happy you want to get with the grinder/hammer ). I like tall skinny tires both for off-roading and mpg. Should have enough torque to be plenty driveable.The notable increase in comfort is due to the taller sidewall (xxx/70Rxx). I'm planning to get /80 on mine with strut spacers and R bags for the exact same reasons you are. 165/80/15 vs 205/55/16 looks to be about 2lb weight reduction per corner (assuming new Al 4.5" rims).
Old 05-31-2020, 01:02 AM   #46 (permalink)
Originally Posted by bobo333 View Post
Mine currently has a 2.6L efi motor from a TR magna in it so I don't expect to have any issues fitting the Prius system, the hardest part will be adapting the output of the CVT into the input of the L300 transfer case to retain low range and 4x4
I was actually considering fitting the Prius C engine and its HSD system on the transverse position and keeping it FWD. Well, maybe you would consider the setup fitted to some Toyota and Lexus SUVs with an electric-driven rear axle, or if you would want to keep the transfer case of the L300 maybe what you should be looking at is the setup fitted to rear-wheel drive Lexus and JDM Toyota sedans such as the Crown. AFAIK there are some provisions which render it quite easier to import an used JDM car if it's hybrid, so maybe you could find a good deal even if you're willing to get it just as a donor vehicle and scrap the rest of the car.
bobo333 (06-23-2020)
Old 06-11-2020, 09:59 AM   #47 (permalink)
90 day: 51.82 mpg (US)
A kamm back/partial boat tail is definitely on the cards built off the rear carrier.
Woohoo!
Old 06-11-2020, 10:02 PM   #48 (permalink)
At first glance it looks like you have a wide diagonal section masked off to paint a different color. I think that'd look nice.
Old 06-12-2020, 09:52 PM   #49 (permalink)
I have no clue if it's legal to retain the standard taxi color in a former taxi in Australia.
Old 06-19-2020, 02:20 PM   #50 (permalink)
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
If you really care just measure spring sag loaded right now, find the rear oem spring rate, ID, OD, and free length... Do the math for the stiffer rate for desired sag and go buy some hyperco springs and slap them on. I feel the Prius needs stiffening up anyways and you can cure your Carolina squat problems simultaneously.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
The Following User Says Thank You to hayden55 For This Useful Post:
