Old 05-29-2020, 11:46 PM   #4 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by EcoCivic View Post
Thanks. Honestly with my Mishimoto radiator my cooling system worked so darn well the way it was that I wouldn't see the improvement, even on a 100 degree day with the AC on the coolant temp sits right at the thermostat's temp of 182-186 degrees like it does in the winter. Without a thermostat, my cooling system would actually overcool the engine down to about 160 degrees even driving down the highway using the AC on a 100 degree day, which is darn good IMO.
I suppose once I finish my fan shroud, install ducting, and reinstall the bumper cover I will pull the thermostat out again and see if the cooling system could cool the engine even more after these mods, I think it will. Did you notice a cooling improvement when you did this?
I did think I noticed an improvement. My temps were better and I needed my fan less often. But it was not an objective test. Just my sense on my daily commute, which I have done the same way in the same car, on the same route all week for 11 years now. I felt confident it was a good mod.
A half inch between the radiators sounds right to me, btw.
EcoCivic (05-29-2020)
