Originally Posted by Chris D.
Frame Extension and Vortex Strake combo
Looking at the way the Frame Extension works by creating little vortex
funnels right in the
Step down area where the extension is attached..
Wouldn't you need clean attached air flowing over that inset?
I believe those Strake boards are going to detach the air
by inducing vortex turbulence off each Strake stick.
Thus, not allowing the Frame Extension vortexs to be created.
I would skip the Strakes.. Plus they are going to add some drag..
