Originally Posted by rmay635703
I would spend the $1.50 each and buy several sizes.
11.64mm is a very familiar sounding size
(m8) expansion bolts go in that size
for example
so I wouldn’t discount anything .
I don't see how expansion bolts are relevant. They use a collar for the expansion part so the OD is larger.
I've checked many places online and unless the information they list is wrong then I don't see the point in physically checking the available wheel studs. It seems like a waste of time. The Dorman catalog only lists one wheel stud in the M10 size and the knurls are too small. The only place I saw one that 'might' have fit was on amazon where the reviews were claiming the knurl was too large and wouldn't fit in the OE application (side x side I think it was). It was only listed at 11mm anyways.
I ordered the bit set. Its gonna be a
bit
before I get them so I will probably see if NAPA has a book of wheel studs I can look through to double check. I've only seen Dorman wheel studs around here though.
The vacuum lines look like a nightmare and a half. Hopefully its simple enough that it just takes time and attention to get it done.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
