Old 06-15-2020, 10:39 PM   #11 (permalink)
me and my metro's Avatar
Economy Saturn - '02 Saturn L200
I really only remember the vacuum line manifold mounted to the firewall. Lots of little steel pipes and solenoids. Yes I remember the three barrel carb with the rich one and the two lean ones.
02 Saturn L200 5 speed- 265k miles
84 Gmc 6.5 na diesel K30 4x4, TMU
2006 Lincoln Navigator, 215k miles
Old 06-15-2020, 11:00 PM   #12 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by M_a_t_t View Post
Have you read/heard about the CVCC before? ...
Yes, I have. It is a great iconic story of how innovative Honda was. The Big Three US could not keep up. Old man Honda was really a giant. And he didn't even want to go to Mars.
...edit: I found (and bought) one that is a loose leaf version (in an original binder!). It says it covers all models 73-77. I might scan some pages in for everyone's viewing pleasure.
ETA 6/24-7/1...
I'll be the vacuum hose schematic on this pre-electronics Honda is a sight!
Old 06-15-2020, 11:27 PM   #13 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
1985 Civic:
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following 2 Users Say Thank You to Gasoline Fumes For This Useful Post:
California98Civic (06-16-2020), Ecky (06-16-2020)
Old 06-16-2020, 01:33 AM   #14 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Even if it fit I'd have to buy new lugnuts. I would rather spend the money and have a metric drill set.
The holes in the drum measure ~11.64 mm. Too big for M10's unless the knurl is alot larger than the threads.
I would spend the $1.50 each and buy several sizes.
11.64mm is a very familiar sounding size
(m8) expansion bolts go in that size
for example
so I wouldn’t discount anything .
The Following User Says Thank You to rmay635703 For This Useful Post:
Old 06-16-2020, 11:05 AM   #15 (permalink)
Cyborg ECU
for example
If it were me, this would be my approach I would try first, before drilling. I can always try drilling as a last resort. The studs are cheaper than new drums.
Originally Posted by Gasoline Fumes View Post
1985 Civic:
LOL! So 1970s ... but also quite beautiful ...
Old 06-16-2020, 12:14 PM   #16 (permalink)
マット
M_a_t_t's Avatar
The Van - '95 Chevy Astro Cl V8 Swapped
Team Chevy
90 day: 7.84 mpg (US)
The new bike - '17 Kawasaki Versys X 300 abs
Motorcycle
90 day: 71.94 mpg (US)
The Mercury - '95 Mercury Tracer Trio
Team Ford
90 day: 34.35 mpg (US)
Toyota - '22 Toyota Corolla Hatchback
90 day: 40.11 mpg (US)
for example
I don't see how expansion bolts are relevant. They use a collar for the expansion part so the OD is larger.
I've checked many places online and unless the information they list is wrong then I don't see the point in physically checking the available wheel studs. It seems like a waste of time. The Dorman catalog only lists one wheel stud in the M10 size and the knurls are too small. The only place I saw one that 'might' have fit was on amazon where the reviews were claiming the knurl was too large and wouldn't fit in the OE application (side x side I think it was). It was only listed at 11mm anyways.
I ordered the bit set. Its gonna be a bit before I get them so I will probably see if NAPA has a book of wheel studs I can look through to double check. I've only seen Dorman wheel studs around here though.
The vacuum lines look like a nightmare and a half. Hopefully its simple enough that it just takes time and attention to get it done.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
Old 06-16-2020, 07:54 PM   #17 (permalink)
Thalmaturge
CHONK - '18 Honda Clarity
Note that it's for a 1985 Civic. Your CVCC should be much less complex.
The Following User Says Thank You to samwichse For This Useful Post:
Gasoline Fumes (06-16-2020)
Old 06-16-2020, 10:26 PM   #18 (permalink)
マット
M_a_t_t's Avatar
Team Chevy
Motorcycle
Team Ford
Yea, I saw that. I can only hope right now.
1995 Mercury Tracer
Old 06-17-2020, 01:22 PM   #19 (permalink)
Cyborg ECU
Obviously, I didn't see that when I commented. Looking forward to your progress.
Old 06-18-2020, 01:48 PM   #20 (permalink)
マット
M_a_t_t's Avatar
Team Chevy
Motorcycle
Team Ford
Tried the super chrome. It's definitely not the same. It does say to apply a clear coat, but I am waiting on some bright red powder to come in first. The left one in the last picture is one I bought on ebay for comparison to real chrome. Maybe once the clear coat is on it won't be so orange peel-ey. I think it will be passable atleast. Especially if all 4 match.
Blasted:
Coated, pre-bake:
Coated, post-bake:
Finished (except clear coat):
Also, I checked the chilton's manual and it doesn't list a vacuum diagram.
1995 Mercury Tracer
The Following User Says Thank You to M_a_t_t For This Useful Post:
California98Civic (06-18-2020)
civic, cvcc
