Old 06-16-2020, 12:26 PM   #31 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
I just bought a lightweight VMS Racing crank pulley for my Honda Civic engine. OEM diameter. Moderately lighter (weighing 2.6 lbs instead of something like 4 lbs or maybe a bit more). I already deleted both the AC and the PS and put the alt on an on/off switch. So, not much to under drive!
Even though 2 lbs reduction on a sock 6 or 8 inch diameter pulley size is maybe less than 1 HP up to 2500 RPM, I drive a 106 HP car. The relative effect is greater. Also, I drive mostly city, and even on the freeway I do a lot of pulse and glide driving, so I run the engine up to 2000 or 2500 far more often than most people. In the city, at a light, I store a bunch of energy in that rotating mass quite quickly in first gear and then maintain it through the subsequent shifts. Ultimately, in the city or the freeway, I put the clutch in to coast and waste all that energy. It is a small amount, but it is wasted over and over and over.
Next will be the flywheel, whenever I get into a transmission swap or service again. Somewhat bigger gains to be had there.
Here is a great discussion and calculator:
https://www.w8ji.com/rotating_mass_acceleration.htm
