Originally Posted by mvrroking
Sorry for bothering you once more. It seems as though the cells are able to cycle via the setting you talked about. I have so far cycled two cells for 3 cycles and the results are unusual to my understanding,
Cell 1- Charge - 7735mah Discharge - 6589mah
- Charge - 7321mah Discharge - 6142mah
- Charge - 7181mah Discharge - 6058mah
Cell 2- Charge - 7405mah Discharge - 0000mah DEAD
- Charge - 7582mah Discharge - 6042mah
- Charge - 7212mah Discharge - 5873mah
Each cycle has a 20min rest period in between and is charging @ 2.0 amps. Cell 1 is clearly the better cell correct?
"Cell"? Are you testing the individual cells of the stick? There are 120 cells in the pack, and this should take you the better part of six months to accomplish assuming you can keep them running full time without interruption.
Did you mean to refer to this as "sticks"?
What is unusual to your understanding?
