Old 06-19-2020, 03:20 PM   #50 (permalink)
hayden55
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
If you really care just measure spring sag loaded right now, find the rear oem spring rate, ID, OD, and free length... Do the math for the stiffer rate for desired sag and go buy some hyperco springs and slap them on. I feel the Prius needs stiffening up anyways and you can cure your Carolina squat problems simultaneously.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
The Following User Says Thank You to hayden55 For This Useful Post:
bobo333 (06-23-2020)
