Originally Posted by JSH
There is much more to cost than just fuel cost. There is the extra cost of the engine, the tanks, training your maintenance workers, stocking extra parts, different oils, etc. Then there is the resale value. Most large fleets only keep their trucks for 3-5 years.
The problem with CNG is range. It works fine for local delivery but the range is a bit short for long-haul. Agility's largest CNG side tank is only 60 DGE. You can add a cabinet tank that holds 175 DGE but that makes for a long truck on a sleeper. Most CNG trucks are daycabs running set routes.
That sounds like a good place to start.
