Old 07-12-2020, 03:36 PM   #91 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
ACEL, Thank you for taking the time to do your testing and post your results. Congratulations on coming up with a good looking wheel cover design. It looks like they could be factory.
As always, when we see wheel covers on this site we would love to see how you have attached them securely and avoid damaging the alloy wheels underneath. Also, from your post I assume that the finished wheel covers were tested on a different day. If you find the time, it would be interesting to see A-B-A testing on the same day and if you see your tank mpg averages going forward.
Thanks again for your efforts.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
The Following User Says Thank You to COcyclist For This Useful Post:
ACEL (07-12-2020)
