Old 07-25-2020, 09:07 PM   #111 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Originally Posted by Tahoe_Hybrid View Post
aha i wish
Do more than wish, GM uses common commands on all plug ins and hybrids. (That have been tested)
If you purchase an appropriate High end GM compatible WiFi/Bluetooth obdii to Android dongle you can then download a $0.99 cent obdii app called my Volt hold made by Brian Baptista.
Of interest The app has a “Engine Off” button, this functionality (thus far) seems to work on non-Volts as well as Volts of coarse.
This app allows the vehicle to use its built in abilities but under your control when you want keeping braking, steering, pumps and other goodies running normally
If you aren’t afraid of Potentially having to be clearing a cel give the app a test.
Brian Baptista has a volt repair Facebook page and may be able to provide you insight into GM canbus sniffing, but I bet a battery monitor and engine on/off button would make you happy enough by itself
Good Luck
Ryan
The Following User Says Thank You to rmay635703 For This Useful Post:
Tahoe_Hybrid (02-06-2022)
