Green, if the name of the game is improving mpg then why not use block heaters, cabin space heaters and all the tricks? There may also be less engine wear and certainly easier starting on our diesels. Generally, internal combustion engines create the most pollutants when cold. FWIW, I sometimes use two heaters on the engine and one in the cabin and do not even notice a difference on my electric bill.
Great mpg numbers on your trip.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
