Old 07-26-2020, 11:43 PM   #169 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by aardvarcus View Post
Yes, this is a temporary step and would definately affect the structure if not replaced. In order to angle in the sides I have to sever all the connections, pie cut out the new angle, and then weld it all back. Based on the initial connections, putting it back as strong or stronger won't be a problem.
Strong, lighter, and more aerodynamic would be a good bragging right.
Cleaning grounds is a vastly overlooked troubleshooting step.
It seems to have worked. Two test drive cycles and no code again yet.
Originally Posted by GreenTDI View Post
I had the same problem. With some help from YouTube I succeeded. It may help you too ... See the post about this in my GreenTDI thread:
https://ecomodder.com/forum/623191-post24.html
Good deal man.
