Welp, mostly figured out the fast idle. Not gonna go into detail, it was mainly just unplugged vacuum ports.
Did a compression test... not good. Apparently metros are toast anywhere below 156psi. I got 91, 126, 96. Ugh, gonna need an engine rebuild. I might be able to limp it through smog, we’ll see.
