Old 08-03-2020, 01:00 AM   #56 (permalink)
M_a_t_t
マット
M_a_t_t's Avatar
The Van - '95 Chevy Astro Cl V8 Swapped
Team Chevy
90 day: 7.84 mpg (US)
The new bike - '17 Kawasaki Versys X 300 abs
Motorcycle
90 day: 71.94 mpg (US)
The Mercury - '95 Mercury Tracer Trio
Team Ford
90 day: 34.35 mpg (US)
Toyota - '22 Toyota Corolla Hatchback
90 day: 40.11 mpg (US)
So I pulled the valve cover off the fiat about a week ago. What I saw was concerning and I realized I never checked the engine in the civic.
For comparison, my 73 Fiat 124 sedan:
And the civic:
Looks good. Then I noticed on the front of the engine by the oil dipstick:
One of the valve lash adjusters. You can see the missing spot on the right side 4th valve away from the front. The screw piece looks fine. The nut is slightly smashed, but relatively unharmed. I figured I'd go ahead and pull the upper timing cover for a look since you have to take the valve cover off first anyway. One of the bolts was loose and the cover ear partially broken. The other is stuck. When I go to loosen it the socket (six point) starts to cam out (like a stripped screw) and won't keep a grip. I tried vice grips, but its pretty cramped and I can't get any except the smallest to fit and still had no luck. A friend has a set of rounded head sockets I am going to try and worst case is I either weld a wrench to the bolt head to break it loose or I try to cut the head off to salvage the cover and attempt to remove the exposed stud. Any other ideas?
Also if anyone wants to help me look for a replacement timing cover this is the only part number I could find for it. TIA.
11820-657-010
https://www.hondapartsnow.com/genuin...n=pd:3449205,7
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
The Following User Says Thank You to M_a_t_t For This Useful Post:
California98Civic (08-04-2020)
