Old 08-15-2020, 10:32 AM   #5 (permalink)
320touring
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
After the Burd had made generally positive noises (or at least no obvious distain expressed) I decided that this was to be the chariot for our impending trip to Skye.
With that in mind, it was time to prep it for the 600ish miles it will be doing.
First up was the wet Vac - starting with the passenger seat and carpet.
Seat before
Seat after
Carpet before
Carpet during
Carpet after
Armrest before
Armrest after
After that little lot, the tank of the wet vac was Minging!
I then carried on and did the other seats and carpet.
It scrubbed up lovely, and is now nice and clean.
All in all, it was about 4hrs of cleaning over two days. Inside is much cleaner, and the car smells significantly better.
Next up was a level check - everything seems fine, bar an incontinent washer fluid bottle.
I did spot this fine piece of engineering though- how to make a cable throttle work with electramatricity..
Next was as run to the petrol station to fuel up and check the tyre pressures.
The left rear was at 13, so I'll need to keep an eye on that. All the others were close to the desired 34psi.
Time to feed it, it has a 60L tank, so I am hoping for more than 500 miles from a fill.
ID:	28943   Click image for larger version
ID:	28944   Click image for larger version
ID:	28945   Click image for larger version
ID:	28946   Click image for larger version
ID:	28948   Click image for larger version
ID:	28949   Click image for larger version
ID:	28950   Click image for larger version
ID:	28951   Click image for larger version
My Blog on cars- Fu'Gutty Cars
http://fuguttycars.wordpress.com/
US MPG for my Renault Clio 182
