Old 08-30-2020, 09:18 PM   #111 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Originally Posted by GreenTDI View Post
The seats are out, but what you see is the backrest, which is anchored in the chassis with bolts. Too big job to build in and out every time
I love it Green! I did a conversion of an old Dodge Caravan that I have. It is so much better than a tent.
You may want to take a closer look at those seat backs. I’m not sure about the Skoda but on my Golf the seatbacks slide out in a minute or less. On the driver side there is a plastic catch that slides back with a flat blade screwdriver and it comes forward and slides off the middle post. Almost no tools required. The 2/3rds seat back is heavily reinforced to hold the center seatbelt in a crash. I removed the seatbacks and spare to remove almost 100 lbs of unnecessary weight in my car.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
