Old 09-03-2020, 04:04 PM   #323 (permalink)
freebeard
elemental.medium.com: A Supercomputer Analyzed Covid-19 — and an Interesting New Theory Has Emerged
A closer look at the Bradykinin hypothesis
This is interesting.
Back when I had the Covid-like symptoms (and shook them), the medical establishment refused to discuss the theory that it is a blood-borne disease that precipitates iron out of hemoglobin and it collects in both lungs.
Now AI is telling us it is a vascular disease
As bradykinin builds up in the body, it dramatically increases vascular permeability. In short, it makes your blood vessels leaky. This aligns with recent clinical data, which increasingly views Covid-19 primarily as a vascular disease, rather than a respiratory one. But Covid-19 still has a massive effect on the lungs. As blood vessels start to leak due to a bradykinin storm, the researchers say, the lungs can fill with fluid. Immune cells also leak out into the lungs, Jacobson’s team found, causing inflammation.
And Covid-19 has another especially insidious trick. Through another pathway, the team’s data shows, it increases production of hyaluronic acid (HLA) in the lungs. HLA is often used in soaps and lotions for its ability to absorb more than 1,000 times its weight in fluid. When it combines with fluid leaking into the lungs, the results are disastrous: It forms a hydrogel, which can fill the lungs in some patients. According to Jacobson, once this happens, “it’s like trying to breathe through Jell-O.”
And this is interesting as it applies to me:
By acting like a natural ACE inhibitor, Covid-19 may be causing the same effects that hypertensive patients sometimes get when they take blood pressure–lowering drugs. ACE inhibitors are known to cause a dry cough and fatigue, two textbook symptoms of Covid-19.
I thought the dry cough was from using a one-hitter.
redneck (09-04-2020)
