Old 09-10-2020, 11:00 PM   #339 (permalink)
freebeard
A proper dome has an oculus. A hole facing the sky. It could be a cylinder silvered on the inside* with tractor tire inner tubes stacked on the outside. They must have 100 gallons capacity each. The weight would act like a keystone and make the shell stronger. They could be pressurized (fishnet sleeve) and extend the reach of a RainBird. (If the cylinder tapers toward the top light focuses at the center, if it tapers toward the bottom it throws light to the sides.)
Originally Posted by redneck
This tactic and the play book was written about 51 years ago.
youtube.com/results?search_query=yuri+bezmenov+call+of+duty
edit:
At youtu.be/IqzoG_omhyc?t=7096 he draws a 'Q' in the air. Just sayin'.
