Old 09-10-2020, 08:13 PM   #331 (permalink)
Fires 🔥 like those are no joke.
I hope you have a plan if things go wrong.
Stuff is replaceable.
Donald J Trump 8/21/21
Disclaimer...
But...
I play one on the internet.
Old 09-10-2020, 08:23 PM   #332 (permalink)
90 day: 29.78 mpg (US)
There's a large pond closeby. Worst case I'd be in it, breathing through a respirator.
I'd take the kayak down there and float under the small footbridge to keep the embers off my head.
Old 09-10-2020, 08:29 PM   #333 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
Great. Oregon's fire is worse than just a bunch of idiots with a gender reveal party:
Wildfires Live Updates: Destructive Oregon Fire Investigated as Arson
As if wildfire season weren't bad enough.
Transmission type Efficiency
Old 09-10-2020, 08:44 PM   #334 (permalink)
Sounds like fun in any case. My neighbor's plan is to go jump in the river, but we're on the far side of it.
I have a RainBird on the roof, running off a 3/4" hose. But I have a bigger RainBird that I want to put on an unused utility pole. I'm trying to organize an anarchist fire department. I have a 500gallon tank, with a sump irrigation pump I could cover two neighbors in each direction. The Lake Drive Volunteer Fire Department because the lane floods in rain.
_______________
Our president just concluded remarks at Freeland with an outro of the Village People. That's an epic level troll playing the original YMCA instead of the parody.
_______________
Fat Charlie — It was embedded in some other video but I saw a 12 hour weather satellite view of the West coast. 10 fires you can see from space eurupted simultaneously along I-5 between Portland and San Fran.
Want to know why? The State police were deputized so all those Facebook posers can be run to ground. Downtown became unviable after the firewalker.
Old 09-10-2020, 08:53 PM   #335 (permalink)
Rat Racer
What I want to know is why someone would deputize a cop.
Old 09-10-2020, 09:02 PM   #336 (permalink)
Federal jurisdiction.
Now I'm listening to the replay while they are waiting for Air Force One to roll up and they are playing a playlist that I wish I had as a radio station. Currently — Sweet Child of Mine.
Is this a great timeline or what?
Fat Charlie (09-11-2020)
Old 09-10-2020, 09:15 PM   #337 (permalink)
Arson...
https://thepostmillennial.com/antifa...-in-washington
https://nbc16.com/news/local/man-see...ire-chief-says
https://www.oregonlive.com/pacific-n...uties-say.html
https://www.khq.com/news/arson-suspe...f5dca5965.html
https://www.q13fox.com/news/wsp-man-...67-in-puyallup
https://www.oregonlive.com/crime/202...hief-says.html
https://www.oregonlive.com/pacific-n...an-caused.html
https://www.lawenforcementtoday.com/...lanned-attack/
Facebook is deleting posts of reports of suspicious people left and right. There was one that described two people trying to start a fire in a hayfield and a description of what they were wearing, the vehicle and location. It was up for a while and now it’s gone.
They’re covering for the scum...
This tactic and the play book was written about 51 years ago.
(starts at 2:06)
https://youtu.be/FwwNH_r2muw
Disclaimer...
But...
Old 09-10-2020, 09:34 PM   #338 (permalink)
My trip to Ace was intended to pick up 3/4" male hose to 1/2" female sprinkler head adaptor since I have a ton of those laying around now (replaced with better heads). The adapters were crazy expensive, so I bought a 2 pack of impact sprinklers with an 80' diameter reach. Put a screw in the gable end of the roof and hung 1 sprinkler there (couple of zip ties), and used a tie-down strap to secure the other one to a vent on my roof. I've got all but a 2' strip of roof covered with that, and most of the surrounding yard (and a bit of the neighbors).
I was thinking, if I could accomplish that in about an hour, I could purpose build a sprinkler head at 4 locations on the roof in a few hours and $40 of materials. Don't know why all houses don't have this built in. If I get an evac call, I turn on 2 hose bibs and leave knowing the only way the place catches fire is for the forest across the street to burn too hot.
Maybe I'll set something more permanent up and run it 4th of July also...
Finally, it would be a simple matter to connect all this to my sprinkler valves/controller. From an app I could turn it all on. Program Google so that when a smoke detector goes off located on the roof, sprinklers come on automatically.
More detailed video of redneck fire suppression:
https://drive.google.com/file/d/1b0D...ew?usp=sharing
Old 09-10-2020, 10:00 PM   #339 (permalink)
A proper dome has an oculus. A hole facing the sky. It could be a cylinder silvered on the inside* with tractor tire inner tubes stacked on the outside. They must have 100 gallons capacity each. The weight would act like a keystone and make the shell stronger. They could be pressurized (fishnet sleeve) and extend the reach of a RainBird. (If the cylinder tapers toward the top light focuses at the center, if it tapers toward the bottom it throws light to the sides.)
youtube.com/results?search_query=yuri+bezmenov+call+of+duty
edit:
At youtu.be/IqzoG_omhyc?t=7096 he draws a 'Q' in the air. Just sayin'.
Old 09-11-2020, 03:16 AM   #340 (permalink)
Here it is:
MR. OBVIOUS t=451
