09-11-2020, 06:15 PM
#32 (permalink)
Originally Posted by aerohead
In Figure 4.54, at the bottom of the table you can see the separation-induced vortex-drag increasing with the down-slope angle, up until 'burst' occurs. This is very important with respect to cars like the 911/ 912.
In Figure 4.55, all the data presented is for separated flow and high vortex-drag. The drag minimum, and lower lift occurred at 15-degrees. You can clearly see the trend line down towards the 15-degree point on the table. And above, in Figure 4.54, you can actually see what the vortex-drag component is @ 15-degrees. The lowest lift occurred at the original roof contour ( actually on the 'template', but at high truncation ).
With respect to fastback rear lift exceeding notchback rear lift, some counterfactual evidence is presented in Hucho's Figure 5.9, on page 221.
* A close examination of the lift table reveals a CL 0.4500 for the fastback, while the notchback version of the same car is CL 0.5085.
* The lift relationship for the two cars remains until 29-degrees of yaw, where they're identical rear lift values, then the fastback overtakes the notchback as the table ends, at 30-degrees yaw.
The squareback shown, registered CL 0.2390, however this car is a Type 36, not a Type 31, as with the upper two cars. It, technically would not be an apples-to-apples comparison.
The table also provides the asymptotes for each car's maximum crosswind CL.
Normal mix of errors (eg comment re Fig 4.55) and irrelevancies (eg bringing in old-shaped notchbacks with separated flow).
I'll let people look at the diagram and make up their own minds as to what it shows with regard to:
- separated flow, attached flows and resulting wakes.
- lift of fastbacks versus squarebacks
You would honestly think the diagram is clear enough for anyone to understand...
