Old 09-15-2020, 02:52 AM   #3551 (permalink)
JulianEdgar
Article using Ecomodder template, picture below is of another project.
https://www.google.com/amp/s/occamsr...-template/amp/
It's just vapourware - he hasn't done anything (yet, at least). And his final version uses the template in a very creative way - note the wheels way off the ground. Not that matters, of course - garbage in, garbage out.
However, much more interesting is his racetrack testing of drag and downforce/lift - methodology here and results here.
Testing methodology looks fine - coast downs only at high speed (90 - 70 mph) - and ride height and spring forces measured for lift/downforce.
aerohead (09-16-2020)
