Old 09-15-2020, 12:48 PM   #55 (permalink)
Xist
For some reason I thought that I had one 16 GB module, but Task Manager shows that I am using 2, presumably 8 each.
So, use half of my RAM, and if it crashes within a week, swap?
I ran Memory Test 86 last night. It took over 3 hours and showed zero errors. Technical support kept saying that it sounded like I had bad memory or graphics until everything passed the test.
Then he told me that everything is fine.
Everything is always fine until it crashes!
I still cannot run all of the Lenovo Diagnostics tests. It still tells me "Test aborted because a system event that could compromise the outcome has happened" when it tries to test the video cards. I asked in the official forums how to remedy that.
I will let you know if I receive a response.
