-5 and beyond
Cold soak with -5F as the low for about 6 consecutive days at the lot -- covered in ice, went to start it during a +3F warmup (2 HOT summers, EOC-ing over that time, and about 4-5 years on the batt). Cleared the ice/snow first (my personal coolant is on "C" now). Really slow cranks, 4-seconds later, and it fires! Acura stock replacement... worked well so far. Still waiting for that day to call AAA.
High idle at about 2000 RPM, "D" selected -- 2 seconds to engage, very slow to shift to 2nd (forced manual). The fluids have to be thick. Meanwhile, I'm frozen! After about 5-10 minutes on the highway and it's warm (gotta hand it to the rad-block -- simply a cookie sheet modified to block the frontal area of the rad area). Crummy mileage on that tank, tho -- despite the tune up.
More cold on the way, not quite the Dakotas or the Canadian Plains, but still windy and cold.
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
 _
 _
