Old 09-23-2020, 02:38 PM   #12 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
camera boom option
I've shot video of tuft tests on numerous cars by mounting a small camera on a boom that's attached aft of the area being filmed (obviously to minimize aero interference from the camera rig).
3 examples:
1) 2000 Honda Insight
From thread: MetroMPG's Honda Insight boat tail extension (cardboard) tuft video; ABA test +9.7%
The cord tied between the two booms adds tension to prevent the camera from bouncing.
2) Similar set-up on my 2nd gen 2004 Toyota Prius:
From thread (starting around post #100): The Premier's Limo: 2004 Toyota Prius "winter beater" ecomodding thread
3) And the current car (1990 Miata MX5) - I didn't get a shot of the camera boom itself, but in this case it was a rigid DIY tripod of aluminum tubing, liberally duct taped to the rear & side of the car:
From thread: "MPGiata" modding thread: aiming for 50 MPG with a 1990 Miata. Update: success, 55 MPG
The other two tripod legs are out of the frame.
Cameras with wider angle lenses are better because you can use a shorter boom (Prius boom is probably 1/2 the length of the Insight's).
Obviously this approach is only practical/safe if the road you test on is free of obstructions/pedestrians/cyclists!
ID:	29180   Click image for larger version
ID:	29181   Click image for larger version
The Following 4 Users Say Thank You to MetroMPG For This Useful Post:
COcyclist (10-23-2020), freebeard (09-23-2020), M_a_t_t (09-23-2020), skyking (09-23-2020)
