Ive never owned a car with factory DRLs (my newest vehicle is a 92 Pontiac Trans Sport van). I have heard about how some vehicles can disable the DRLs with the e-brake switch. So how does that flash the lights? Do they turn on when starting then go off once it realizes the e-brake is on?
Or is more like you want the lights to stay on when EOCing?
The lights wont flash if you just plain start the car. The fuel pump needs to run to get the car started, as well as keep it running. Now if you turn the key to on and leave it there without starting, the lights will come on while the fuel pump primes for a second or so, then go off.
There are delay circuits online, you can build one, then connect it into your power going to the relay coil. Youd have to figure out how much delay you want.
Winter daily driver, parked most days right now
Summer daily driver
