Old 10-02-2020, 01:35 AM   #40 (permalink)
cRiPpLe_rOoStEr
Originally Posted by EcoCivic View Post
Probably. I like the idea though, some type of screen may help prevent my AC condenser from being punctured by debris a second time. The problem I see with that is the screen would block quite a bit of airflow since it would need to be pretty fine to be effective.
It's still likely worth to try. As you mentioned an increased air speed around the radiator and condenser, most likely it wouldn't do much harm.
The other problem is that the screen would still need to be cleaned periodically just like the condenser does, so it wouldn't really solve the problem. I think my best bet is to just live with it and clean the condenser every month or so as I usually do, it only takes a few minutes to clean it off
Having an easily-detachable screen in order to clean it may be worth too.
EcoCivic (10-02-2020)
