Old 10-05-2020, 08:01 PM   #90 (permalink)
JulianEdgar
When I was first reading about the template, it was made clear that it was a 2-D form and that actual 3-D cars would be able to deviate from it quite well.
But it was a starting point. Short of making and testing multiple prototypes with your daily driver, you could do a lot worse than building to the template, testing, and being happy with the results.
As I said, it's obviously gone down a waaay different rabbit hole in the years since!
And, "you could do a lot worse than" is, with respect, rather strange logic isn't it? Don't we want people to achieve the best that's possible for them?
That's just like saying: "When tuning, run an AFR of 12.5:1 at full load - you could do a lot worse than that, you know." Well, yes you could - but it's also very likely you could do better.
