I am going to try and make another upper grill block for the mercury. I cut a section out of a water heater skin and just wanted to attempt to make the right curve that I wanted. I only used the shrinker (blue in background of last picture). I did use the stretcher (yellow one on right) to flatten out the hood side a little bit because I over shrunk it. I need to make the flange not so thick. It made it difficult to get the metal to move. My vise is a little high too. I ended up using a stool
so I could get more leverage on the shrinker.
Pics and captions:
I just cut out a small section of a water heater skin. This piece is probably about 3"x10"
I flattened the piece back out some more and put it in the vice with a 1" piece of square tubing and used a carpenter's hammer to bend it over to a 90
And finally the end product. You can see the cut out piece on the right, that is the bumper side. The left end of the piece is towards the hood. Most of the curve is towards the bumper end. I wanted it to be kind of flat as it meets the hood. It lines up with the hood curve a little better that way.
The longer version of this post can be seen here:
https://ecomodder.com/forum/showthre...tml#post632893
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
