Old 10-09-2020, 06:33 PM   #3580 (permalink)
Bicycle Bob
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
Could be a CyberCityHawk if it was in 304 stainless steel. It's got the chamfered front corners and longitudinal razor edges.
304 SS has about 1/6 the strength-weight ratio of 6061 T-6 Aluminum (the most common aircraft alloy.) It seems an unlikely choice for a vehicle which already has undersized, inefficient lifting elements.
The SR-71 needed SS for the heat resistance and oxidation resistance when hot, but a new industry was created to use Titanium for barely acceptable heat resistance at half the weight.
The Following User Says Thank You to Bicycle Bob For This Useful Post:
freebeard (10-09-2020)
