Old 10-10-2020, 09:25 PM   #32 (permalink)
JulianEdgar
Originally Posted by M_a_t_t View Post
I tried measuring the pressures on the separation edge I had been trialing, but my set up wasn't that great. So I will re do it, but I figured I might as well post where I put the puck for testing to see if anyone thinks I should try in a different location before I repeat the same test. I didn't do any testing with the bumper portion of it, just the lights. Is it important that I test on the same side if I do a there and back check?
I also noticed that the modified side is clearly dirtier than the stock side.
That looks fine but you will probably be needing to use a pitot tube reference rather than a pressure tank (not sure which you are doing). Just leave it in that position for your two-way average.
