Old 10-10-2020, 07:35 PM   #31 (permalink)
マット
M_a_t_t's Avatar
The Van - '95 Chevy Astro Cl V8 Swapped
Team Chevy
90 day: 7.84 mpg (US)
The new bike - '17 Kawasaki Versys X 300 abs
Motorcycle
90 day: 71.94 mpg (US)
The Mercury - '95 Mercury Tracer Trio
Team Ford
90 day: 34.35 mpg (US)
Toyota - '22 Toyota Corolla Hatchback
90 day: 40.11 mpg (US)
I tried measuring the pressures on the separation edge I had been trialing, but my set up wasn't that great. So I will re do it, but I figured I might as well post where I put the puck for testing to see if anyone thinks I should try in a different location before I repeat the same test. I didn't do any testing with the bumper portion of it, just the lights. Is it important that I test on the same side if I do a there and back check?
I also noticed that the modified side is clearly dirtier than the stock side.
I will have to look around and see if I can rig up a pitot reference. Right now I have the propane tank seen in the trunk as a reference.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
Old 10-10-2020, 08:25 PM   #32 (permalink)
That looks fine but you will probably be needing to use a pitot tube reference rather than a pressure tank (not sure which you are doing). Just leave it in that position for your two-way average.
Old 10-10-2020, 08:27 PM   #33 (permalink)
マット
M_a_t_t's Avatar
Team Chevy
Motorcycle
Team Ford
I just edited to add I was using a tank, but will look for something to rig up the pitot tube.
1995 Mercury Tracer
Old 10-10-2020, 08:36 PM   #34 (permalink)
Tank is fine for most testing but edge-of-wake testing is hard to do accurately without a pitot static port reference. Don't forget the pitot needs to be centre, front of car, at least 800mm above hood.
Old 10-10-2020, 08:54 PM   #35 (permalink)
マット
M_a_t_t's Avatar
Team Chevy
Motorcycle
Team Ford
What is that number based on? Asking because in one of your other posts you used 2.2 meters off the ground and front corner (at least in picture it was).
Permalink:
https://ecomodder.com/forum/showthre...tml#post625899
Is it situational based on where you the probe you are measuring with is or?
1995 Mercury Tracer
Old 10-10-2020, 11:22 PM   #36 (permalink)
Permalink:
That big pole's height and location were my starting point, but I found a central, front pole of 800mm gave the same results. And a bit less obvious!
COcyclist (10-23-2020)
