Old 10-10-2020, 11:22 PM   #36 (permalink)
JulianEdgar
Originally Posted by M_a_t_t View Post
What is that number based on? Asking because in one of your other posts you used 2.2 meters off the ground and front corner (at least in picture it was).
Permalink:
https://ecomodder.com/forum/showthre...tml#post625899
Is it situational based on where you the probe you are measuring with is or?
That big pole's height and location were my starting point, but I found a central, front pole of 800mm gave the same results. And a bit less obvious!
COcyclist (10-23-2020)
