Old 10-12-2020, 10:54 AM   #1 (permalink)
Vman455
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Difference in displayed vs measured MPG: Statistical Analysis
In the garage, I have recorded the MPG displayed on the factory gauge for almost every fillup. Leaving out the two I missed, there are 178 fills with these data. Since I'm taking a statistics course this semester, I thought it would be fun to run a simple analysis. Here's what I found:
Using the quartile method to identify outliers, I removed two data: the two times when the factory display underestimated calculated MPG. The remaining 176 fills chart nicely into a normal curve.
Median = 3.0 MPG difference
Mean = 3.04 MPG difference
Percent difference shows an even clearer normal curve, and again median and mean are very close to each other.
Median = 5.58% difference
Mean = 5.563% difference
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following User Says Thank You to Vman455 For This Useful Post:
M_a_t_t (10-16-2020)
