Still haven't messed with the passenger mirror. I did some work no the rust on the wheel well though. Just a temporary fix though. I think it turned out ok. I didn't really want to mess with it at the time and I needed to fix a coolant leak on my mom's car (08 hyundai veracruz) so this is what I ended up with. I haven't finished the grill block that I mentioned in a different thread yet either. I need to modify the driver side end plate to make up for the broken bumper before I can finish it.
The hole was actually prettly large (and seemed to be getting bigger quickly)
I was planning on trying to weld in 2 pieces. The first part of the wheel well was pretty flat and only curved in one direction. So I was going to make this piece and weld it in there then make the rounded side of the well. Like I said I didn't really feel like messing with it then so it's now more of a deflector than a real fix. It blends in pretty well though.
That wagon I mentioned earlier in the thread is gone. I also started a new job that is more highway (~24 miles one way) than my previous job and traffic requires you go the speed limit or above (people regularly doing 60-65 mph in a 55) so any aero mods I do should let me reap the reward faster. Plus it's 2nd shift (
) so the wind is usually a little calmer when I get off so I can probably do some quick testing on my way home from work. I also quit the newspaper route I had been doing.
Preliminary results (adjusting MPGuino currently) show low to mid 30's for the trip.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
