Old 10-20-2020, 02:46 PM   #149 (permalink)
redpoint5
90 day: 29.78 mpg (US)
... if your new laptop has no issues on other WLANs, for instance a coffee shop, then it’s probably an issue with modem, WiFi router, or ISP. If the problem is that you aren’t getting an IP address, I suspect the router.
WiFi routers are notorious for needing to be periodically rebooted. You might set it to reboot every morning at 4am
